My double din headunit in Mk2 golf
Discussion in 'ICE' started by davefromhull, Aug 4, 2010.
  1. davefromhull Forum Member
    Hull, East Yorkshire, England
    My Double Din Unit in dash
  2. muppet9966 Forum Member
    Uxbridge, United Kingdom
    Wow, very nice and tidy
  3. davefromhull Forum Member
    Cheers, the biggest pain was the heater control relocation it took a lot of fiddling after removing the centre vents to fit as it's all mechanical. Did it in the end. Then flush fitted a reverse cam into the boot door handle area (I'll have to post another pic) and a wire to gearbox and it works a treat :-)
    That's in addition to the freeview digital tv, DVD, USB, sd, gps, iPod control and charging, Bluetooth dialling and audio streaming from me iphone4 that the unit does :-)
    ...plus the rare fisher 6cd centre console holder :-)
  4. davefromhull Forum Member
    Not that I'm bragging lol
  5. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    What's it got to do with 'Engines' though? [:s]
  6. davefromhull Forum Member
    Pants I've put it in the wrong section like an imbecile. Can anyone move it?
  7. dragonfly
    dragonfly Paid Member Paid Member
    Birmingham
    Nice work, looks good!
  8. Gaz_b Forum Member
    The specs on those headunits seem very impressive for all the price of them. Picture in Picture etc.
    I don't think I'd have the nerve to do what you did to fit one in my mk2 though, I don't think I'd ever get it to look that neat.
    Looks very tidy.
  9. Gaz_b Forum Member
    Don't suppose you've any pictures showing the menu's and browsing and playing media from cd/dvd or ipod etc. I'm quite tempted to pick up one the slide out screen versions for my mk2.
  10. davefromhull Forum Member
    Ill try get some pictures posted up. I never opted for the slide out screen as although much easier to install, being a touchscreen the screen would bend back all the time when being pressed. Also the screen ends up blocking your view of the road as it flips up over the height of the dash and is a bit of a distraction...
  11. dUff
    dUff Administrator Admin
    Everybody Offline - looking good
    Nice work ! , whats the SSA switch do as i had one in my car but was not connected up ?
  12. RIP-MK3 Forum Addict
    sunbury on thames
    that looks great, as do your dials
  13. Chalky White Paid Member Paid Member
    SSA
    Hi
    SSA refers to, if I may quote Wikipedia's definition of a MarK 2 Polo;
    An early-stop-start ignition system (called SSA) that would cut the engine when idle for more than two seconds to save fuel whilst temporarily stopped in traffic, and re-start the engine when the gear lever was moved to the left in neutral. The system could be enabled or disabled by means of a toggle switch below the light switch. Similar systems were later used on the Volkswagen Golf Mk3. Similar systems were developed by other car manufacturers.:)
    Regards
  14. Chalky White Paid Member Paid Member
    SSA
    Hi
    Duff, it also occurs to me that you may well already know what an SSA switch does - I didn't - and just be asking what its used for in the Double din dashboard install![:s]
    Either way, I've learnt what it stands for!
    Regards
  15. dUff
    Cool i had no idea what i did ,so cheers for finding out
  16. Gaz_b Forum Member
    How's the headunit going for you? I'm tempted to get the double din like yours for my ibiza cupra.
  17. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Lush!! You could fit a matress and sink in the back and sell your house!!
  18. davefromhull Forum Member
    thanks for the comments guys - the SSA switch I have isnt wired up at all in fact was never there originally I just shoved it in (after replacing the bulb with a blue led along with the other switches) just to fill a gap :o)
  19. killthezombie New Member
    this is amazing.
    I'm just a few days away from possibly buying a MK2 GTI, and in doing my homework on head units, I'm absolutely blown away by this.
    can anyone shed any light on how the double din would have been screwed in place?
