My First MK2 Golf 1.8t Conversion HELP!
Discussion in 'Mk2' started by Bhav, Jul 24, 2017.
  1. Bhav New Member
    Hello all.
    It is a pleasure to join Club GTI.
    I have owned a MK2 for a little under a year now and its by far already the best car I have ever driven!
    Even though it is only a 1.6 Driver with a Webber Carb it never fails to put a smile on my face. [:D]
    So recently I have come across a Mk2 1.8T AUG engine and an O2J Gearbox and have a few questions in regards to the conversion.
    Which Mounts would I require?
    Who is the best person to make an Engine Loom? (The car is a H reg and will be looking to keep the Mk2 Dash)
    Are MK2 16V Drive Shafts adequate for the engine?
    Would a 4 x 100 16V Brake Setup be enough stopping power for this 1.8? (baring in mind it will only be a standard 1.8t with a k03)
    Where can I get a full exhaust system made?
    Which Pedal box can use? (Looking to keep a Cable Clutch)
    Thanks,
    Bhav
    P.S - I will continue to post once I start the Conversation!
    1. G60/corrado/passat 4 cylinderfront & rear assuming you keep mk2 subframes, any 02a gearbox so same donors plus 6 cylinder and mk3 golf 16v/tdi/vr6
    2. ask around, plenty guys out there. I can do them if you can wait a long time, James E loms or Chris Bellman on facebook, few ebay guys etc.
    3. yes
    4. probably, but while there I'd go full G60 280mm its the same work. potentially cheaper/easier as the calipers and carriers can be had from pre-96 mk3 gti, 16v and vr6
    5. whereabouts are you? style dynamics down south can sort you if you're nearby :thumbup:
    6. keep the mk2 one, use the SEAT conversion kit:
    http://clubgti.com/showthread.php?107068
  3. Bhav New Member
    Thanks RubJonny
    I will try and source these parts [:D]
