New coil pack?
Discussion in '8-valve' started by Night trucker, Feb 2, 2022.
  1. Night trucker Paid Member Paid Member
    Darlaston
    Hi all.
    I have a 2002 2.0 gti,always used E5 but had to put £10 of E10 in last night,put £15 of E5 in today but with the E10 started to mis-fire and engine light flashing,been to the garage said without plugging it in could be the coil pack playing up,(fuel light was on when I put the E10 in),I might regret this but how much is a coil pack fitted please?
    Thanks
  2. PhilRyder
    It looks to be a DIY job and the part is about £35. There are a couple of useful utube vids.
    Using E10 should not make your car behave like that so it must be a coincidence.
  3. Night trucker Paid Member Paid Member
    Darlaston
    Thank you for a quick reply,I shall look on utube later,thought it was going to be more than that
  4. Night trucker Paid Member Paid Member
    Darlaston
    Update,called the AA as didn't want to drive it to the garage mis-firing,AA bod plugged the computer in said mis-fire on cylinder 2.got to take the inlet manifold off to diagnose it then would open a can of worms and lots of £££££ to try and fix it.
    Hate to think how much it is to fix or could end up scrapping it still got 4 months MOT aswell
  5. PhilRyder
    Don’t go jumping to the worst conclusions. Misfire could be down to the coil pack.
    I don’t get why you would need to take the manifold to diagnose before you have investigated the external possibilities.
  6. Night trucker Paid Member Paid Member
    Darlaston
    AA man said he can't get to the coil pack leads or spark plug without taking the inlet off,couldn't do any more outside the house take it to the garage.the garage said have to take the inlet off aswell to diagnose it
  7. PhilRyder
    So air inlet, not manifold?
  8. Night trucker Paid Member Paid Member
    Darlaston
    Yes sorry,either way could be expensive, garage said take it apart replace the coil pack put it back together and then it might not start after all that,drove just over a mile to get home,garage said could be compression issues
  9. dodgy
    Is it individual coil packs or a combined one?
    Can you just swap one to see if coil if misfire moves with it?
    May be a plug even possibly.
  10. Night trucker Paid Member Paid Member
    Darlaston
    Combined coil pack,AA man said can't get to cylinder 2 without taking it apart and couldn't do it roadside to check plug lead or coil pack
  11. PhilRyder
    Have a look at the vids on utube, it really doesn’t seem difficult to do.
  12. rubjonny
    upper half of the inlet is only a couple allen heads and some support bracket bolts, really isnt a big deal. but heres a vid showing how to remove plugs without pulling the inlet:
  13. Night trucker Paid Member Paid Member
    Darlaston
    Thank you very much,AA man said couldn't be done
  14. Night trucker Paid Member Paid Member
    Darlaston
    Will finally get time to try and swop the plugs tomorrow
    Is it easy enough to get the electrical connector off,be easier if it was out the way?
  15. PhilRyder
    Are you going to replace the plugs or do the coil pack first to see if that is the problem?
  16. Night trucker Paid Member Paid Member
    Darlaston
    Hi Phil
    Was going to try the plugs first,being honest not got the funds at the moment to do the coil not attempted replacing a coil before
  17. rubjonny
    injector plug, you need to squeeze the tab on the left of the pic to release the lock clip. sometimes they can fight you, plus it can help to push the plug down slightly so the clip isint under tension to the peg on injector if that makes sense
    Night trucker likes this.
  18. Night trucker Paid Member Paid Member
    Darlaston
    Thank you for all your help guys,couldn't get the connector off didn't want to force it (AA said if I took connector off would need to take it to main dealer to be reprogrammed),as I have never took a manifold off or re-sealed done a coil before,had to take it to the garage,they said £300 it was £70 coil £40 leads and £30 plugs special iridium plugs apparently ,and pressure test rest is labour.
    Bit embarrassing really considering the work done from a bare shell to engine work
    Will put a picture of the manifold tomorrow when she's back all the videos are the manifold all silver mines half silver and black
  19. Night trucker Paid Member Paid Member
    Darlaston
    Just spoke to the garage, changed plug 2 good spark coil pack and leads all good,put new plug in still miss-firing and code come up,he said it's low compression wanted 4 hours labour to take manifold off and do compression test (not done a compression test)and head needs to come off,could be piston or rings,that's done it I think can't afford to get it done and of all the weeks I really need a car
  20. PhilRyder
    Probably less than buying another car?
