Non power steering belt 1.8t?
Discussion in '1.8 & 1.8T' started by Cupra gaz, Jan 4, 2020.
  1. Cupra gaz New Member
    Do they do a non power steering belt for the 1.8t? Reason I ask is my ibiza mk3 is basically a mk2/3 golf and was looking into removing the power steering as it's mainly a track car and getting rid of the nasty pipes and bottle! I've also heard of people fitting electric power steering off a corsa this is something I'll look to do if I dont get along with the non power steering. Unless someone has a neater way to reroute the pipes using dash fittings?
    there are a few lengths mentioned depending who you ask, the one I have saved is this one:
    038 903 137 G - belt for 1.8t without PAS - 906mm
    but double check using the string method roughly what length you need before you buy
