O20 HELP needed. Soddin gearbox
Discussion in 'Transmission' started by Cressa, Nov 9, 2022.
  1. Cressa Paid Member Paid Member
    Right, as I had a couple of hours spare today, i thought i would fit the refurbished 020 gearbox onto the engine.
    Torqued up the flywheel after fitting the bolts and on went the gearbox. I thought all was good so went to try the clutch release arm and it was solid.... would not lift up!! Damn
    So I took the gearbox off and the arm works fine.
    Put the gearbox box back on and same problem
    So I took the gearbox off and the flywheel and all looks correct. The clutch is facing the correct way.
    Last time, put it all together and still solid
    Walked away
    I know I need to take the box off again, but was hoping to get the lot back in the car this weekend.
    Anyway, what are your thoughts?
    Pushrod too long !
    Or have I done something wrong .
    Like cricket, bad light stops play
  2. Zender Z20
    From recollection, so check I'm right... If you mean lift the arm up further than the 9 o'clock position... it'll be nigh on impossible to do it by hand with the 'box mated to the engine.
    It takes the combined power of your foot/clutch cable to do it when it's all connected up and even then the travel's maybe only up to the 11 o'clock position.
  3. Cressa Paid Member Paid Member
    The arm will not move at all when the gearbox is on the engine. It is at about 7oclock and solid.....
  4. Zender Z20
    The black plastic thing, it stops the arm dropping passed a resting point cast into the metal of the bell housing. Removing it / pulling the arm back a little allows it to drop right down (when changing the release bearing for example). Is it on while the arm is below that point, preventing it from rising back up?
  5. Cressa Paid Member Paid Member
  6. Cressa Paid Member Paid Member
    Push rod is 342mm, so seems correct.
    The clutch lever works fine with the box off of the car
  7. Cressa Paid Member Paid Member
    Pushrod approx 35mm to gearbox face when at rest.
    And at this position
  8. Cressa Paid Member Paid Member
    Approx 27mm with lever lifted up. So approx 8mm travel !
  9. Zender Z20
    Think you got your 'box done at a VW specialist? Really grabbing at straws here and don't think it's your issue as the guy's obviously good, but for the sake of covering it...
    Guy that did mine got the release bearing clip and spring wrong when refitting, only realised something was amiss when a small dent appeared from the inside, out on the new green end cap.
    The finger on the arm was travelling too far back, picked up on it early, don't know if it'd have resulted in your problem if not.
    Your obviously reading BrokeVW as you go and his measurements for the rod etc.
    Wish I could help more, but don't know enough beyond my own problems recently.
    Sounds like you're being methodical, all you can do...
  10. Tristan
    If you can get the cable attached, try it, possibly the new pressure plate needs to bed into the new disc, and let the fingers settle.
    Cressa likes this.
  11. Cressa Paid Member Paid Member
    All sorted, thankfully.
    Can I say what the cause was...... I don't actually know. I took all the measurements to check against the Broke info and all seemed correct. Maybe I had the pushrod the wrong way around. All i do know is it worked fine off the car and i kept checking the lever would move as i put the bolts in. The bolts are in and the lever moves with a hard tug. Putting it in gear it moves the flywheel and the drive flanges and if i pull the lever as if i was engaging the clutch, it releases the flanges from driving
    So happy days
    But it did annoy me earlier today
    KeithMac, PhilRyder and Zender Z20 like this.
  12. PhilRyder
    Tell you what though, that’s probably the cleanest engine and gearbox I’ve ever seen!
    Tristan likes this.
  13. Cressa Paid Member Paid Member
    Ha, thanks. But check out how it did look before it was removed this year
    KeithMac likes this.
  14. Tristan
    That's the automatic engine bay anti corrosion treatment!
    Cressa likes this.
  15. watercooled Forum Member
    Nelson,New Zealand
    I agree looks stunning,good to hear you have it sorted.
