Obd 1 vr6 ecu not responding on vcds
Discussion in 'Vagcom / VCDS' started by boab, Jun 2, 2015.
  1. boab Forum Member
    I recently got a flea bay blue kkl cable I downloaded vcds lite plugged in to my skoda superb and my mates vw sharan connects and works a treat reads codes from a lot of modules. So I connected up to my mk2 vr it won't connect to ecu.i have wired in a 16 pin obd port pin 4 ground. pin16 feed. pin7 data from pin 43 on ecu and never bothered with yellow wire I think L line as I've no abs etc.i connect car up ignition on start vcds and try an engine scan it just doesn't see the ecu. am I doing something wrong? My mk2vr is Obd1 distributor model.cheees
  2. boab Forum Member
    Okay tried connecting back up to my vr this is what I get
  3. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    After that port test it should connect fine. As this is a conversion does the ECU actually power up or is this a running car?
  4. boab Forum Member
    Cheers for the reply.yeh car is running fine no issues just wanted the port for future..I save the test after the testing com and try a scan on engine and an auto scan it just keeps coming up with no response from controller .
    I have on my obd port ground on pin4 .feed on pin 16 .pin 7 data from pin 43 on ecu .have voltage on pin 7&16 ground on pin 4 just can't access ecu
  5. boab Forum Member
    Why is the opto/iso no and the Ross design no?
  6. Toyotec
    Ebay cables are not brilliant and can be random as best.
  7. boab Forum Member
    That's what I was thinking but it connects to my skoda reads all controllers just won't access my vr6
  8. Toyotec
    The Skoda is KWP2000 the VR6 is KWP1281.
    Tool and the cracked software may not be backwards compatible with pre EOBD vehicles.
    boab likes this.
  9. boab Forum Member
    Cheers for the comments other than buying a Ross cable is there another cable that would work? Cheers
  10. Toyotec
    Most of the other legit stuff is around the same price.
    Best to look at a place like Gendan for a cable. Well worth it.
    boab likes this.
  11. boab Forum Member
    Cheers ill give them a shout
  12. boab Forum Member
    One thing I checked my vr is early 93 on the k line I have battery voltage I read up on the radio problems but I've cut my cable direct at ecu and on the output from ecu pin43 I still have battery voltage with ignition switched on.should there be that much voltage on a data line?
  13. boab Forum Member
    Thought I'd update this.i got connected I had to connect the L line aswell as the K as the wake up for ecu is sent down the L line and data back up the K line.
