Obd port not working with vagcom. Vagtronics loom mk2 standard ecu
Discussion in 'Vagcom / VCDS' started by alexHxC, Aug 2, 2015.
  1. alexHxC Forum Member
    So as part of my mk2 troubles the obd port doesn't seem to work with vagcom or a diagnostics tools, as part of the vagtronics loom there's a bank of 6 fuses all which seem fine to me.
    Any ideas? Got a multi meter at the ready but if anyone in the Wolverhampton area is free this week and willing to help that would be great!
    Cheers
    does the little led on your vagcom port light up when plugged in? if not check the live and earth, red/white and brown on a stock vagcom port. then you should have your grey/white diagnostics wire back to ecu, what code is it?
  3. alexHxC Forum Member
    Yea it lights up it wasn't my vagcom, I put a request for a group for it as a few people asked in the last thread
    What code do you mean? Standard ecu if you mean that, however I'm unsure what type it is?
    I mean is it an agu or aum/auq, or other code. I only need to know so i can let you know what ecu pin to check :)
  5. alexHxC Forum Member
    Oh sorry bud it's an AGU
    reeto then, its ecu pin 19 you need to check, grey/white to port pin 7 :)
  7. alexHxC Forum Member
    I'll get looking in the morning! Cheers again!
    Ps the new pump system didn't help :/
