Does anyone know if the oil pump and relief valve from an audi ABK engine will fit an ABS block from a mk3?
do you know what car specifically its from, as i think the sump might be a different shape depending on the model. but afaik the main body of the pump is the same as 2.0 8v mk3, just the pickup that might be different
not really no as i say the sump might differ depending on which audi its in, and in turn the pickup might differ. but as i say im pretty sure the pump body is the same as mk3 2.0 8v and so will work in your car, just a case of swap your pickup onto it. will be a nice upgrade in oil delivery too
