Other gearbox for ABF
Discussion in 'Transmission' started by h0r4ex, Feb 5, 2019.
  1. h0r4ex New Member
    Sorry for my bad english. Hello, today i broke my 02A gearbox from original ABF. I want to change with this from 1.8mi. What i need for the swap. ? I need to change all pedals or i can only clutch pedal to change ? My clutch fit in 1.8mi gearbox ? What it's the code on gearbox from 1.8mi ?
  2. stephcasscar Paid Member Paid Member
    mk3 02A from a golf mk3 has a hydraulic system with slave cylinder on gearbox
    if your after a 1.8 system, then a 020 box or 2y box from a mk2 16v gti
    SEAT Toledo, Cordoba and Ibiza ABF have a cable change 02A box
  3. h0r4ex New Member
    Don't want to more 02A gearbox. Now i need to search for 020 gearbox, okey. But i need the all pedals(clutch,brake and gas) ? with shift mechanism from 020 box all to shift knob ? My clutch from 02A will fit on 020 gearbox or i need the 020 clutch ?
  4. stephcasscar Paid Member Paid Member
    yeah, for 020 you'll need a different flywheel and clutch, and there is 2 sizes to worry about 8 or 16v .
    also you'll be going from cable change to rod change so you'll need the rod shifter system
  5. rubjonny
    what car is the engine fitted to?
  6. h0r4ex New Member
    Golf 3
  7. rubjonny
    Ok so you need the gearstick and all of the linkages and the front, rear & gearbox brackets from a MK3 1.8-2.0 8v, to convert the pedal box all you need is a clutch cable as the main pedal box is the same for all models :)
