Part numbers for subframe bolts etc ? Mk2
Discussion in 'Chassis' started by Tristan, Sep 28, 2021.
  1. Tristan
    I've been stripping a GTI that I have to rebuild for a mate, and a disappointing amount of the bolts seem either badly rusty, or possibly incorrect.
    My local VW dealer doesn't want to know, when I ask about older stuff, and we don't have TPS here.
    Anyone able to help me with part numbers for the subframe bolts, front wishbone bolts, and crossmember bolts?
    Pretty please.
  2. GVK
    I found an ETKA disc the other day if RJ doesnt answer I'll install it on my lap top.
  3. rubjonny
    Have a looky here:
    https://realoem.com/
    N 10087403 - rear wishbone, M12x1.5x74 - NLA
    N 10207803 -> N 10207804 - rear wishbone G60/MK3, M12x1.5x78 - 3.48+VAT
    N 90484003 -> N 90484004 - front wishbone, M12x1.5x82 - 3.68+VAT
    N 10209605 - outer subframe, M12x1.5x65 - 3.58+VAT
  4. Tristan
    The bromance is real.
    [:D]
    GVK and rubjonny like this.
  5. BRI
    bri Forum Member
    Ireland
    These are all available still afaik Tristan with the exception of the front crossmember bolts . Got a set of the rado a while back.have the receipt somewehere with the pn,s if required.
    Micheal Moore's parts dept are actually pretty good for older stuff like this I find .
  6. Tristan
    Excellent, thanks for that.
  7. PhilRyder
    Try Westfield Fasteners. I have bought matching bolts from them before base on size etc.
  8. Tristan
    Ah there's loads of good Irish "standard" bolt suppliers, just ideally looking for the OEM flanged head style.
  9. PhilRyder
    Flanged head should be available from any good bolt supplier. That's what I ordered.
  10. NateS2
    Make sure get the correct grade, lots of stuff is 10.9. If you want OEM style get Geomet coated or similar, basically fancy galvanising they gives that corrosion resistant flat grey look
