PB engine fuel pipe size
Discussion in '8-valve' started by valvemiester, Jun 28, 2019.
  1. valvemiester
    Trowbridge
    Hi I wonder if someone could tell me the I.d of the fuel hose onto the plastic injector manifold on a PB engine it's the angled connector on the left on top of the plastic fuel manifold please thanks in advance
    they're 7mm I/D, 8mm is close enough. R9 grade fuel hose is what you want, its tricky to get normal straight hose to fit but if you're careful it can be done
  3. valvemiester
    Trowbridge
    Thanks RJ your awesome :thumbup::thumbup:
  4. Tristan
    I use motorsport spec stainless braided hose, with good quality hose clips. Never had an issue.
