Polo 2006 Gearbox / Clutch Problems
Discussion in 'Fox/Lupo/Polo' started by Richard Mk2, Oct 2, 2014.
  1. Richard Mk2
    London / Bucks
    Right guys, in need of some help. :thumbup:
    A friend of the family owns a Vw Polo 1.2 (2006). Over the last week or so he's had trouble with it, relating to either the gearbox or the clutch.
    Basically, when the clutch is pressed in, a loud whirling noise is present, but when its put in gear, the noise gets noticeably louder and shakes the car violently !
    I'm thinking that the clutch has either gone or is near enough failed altogether ?
    Also, has anyone changed a clutch on one of these engines ? I've offered to give it a go myself to help him out, but need to know if its an easy gearbox off and on job ?
    Any help or info would be much appreciated.
    Cheers. :thumbup:
  2. Richard Mk2
    London / Bucks
    Been doing some digging tonight, and a lot of the symptoms are pointing to the thrust bearing ?
  3. rubjonny
    this would be my suspicion yeah, I would just put a new clutch on it while the box is off though. if its the type with an internal clutch slave cylinder I'd do that as well as sods law it'll break a week after you put it all back together!
  4. Richard Mk2
    London / Bucks
    That's true, thanks Jonny. :thumbup:
    VW quoted him 400 just to look at it ! Which is why I stepped in and said I'll do it for him.
    I'll try and find out if it does have an internal clutch slave cylinder and recommend we change this too.
    Cheers.
