ported abf throttle body woes
Discussion in 'Throttle bodies & non-OEM ECUs' started by new2gti, Oct 11, 2021.
  1. new2gti New Member
    I replaced old tb with used new one as the old one had aftermarket micro switch glued to the side
    ported the new out inlet side and matched on the other
    didn’t go mad and go up to the butterfly, kept it 5mm back both sides
    engine doesn’t like it at all
    car will tick over from cold but as soon as throttle is touched it cuts out and won’t start after
    ive now taken the working switch off the new and put it on the old tb and all good
    any ideas why this may be happening
    any help appreciated :)
    Sounds like the switch is out of adjustment?
  3. TonyB
    TonyB Paid Member Paid Member
    Ammanford, Wales
    That's not a micro switch its a TPS if its an ABF (throttle position sensor). It senses where butterfly is in relation to the throttle pedal and tells the ECU so it can work out where the crank and pistons are etc, so it can set the fuel and ignition accordingly.
    As you can guess if its set wrong it will mess everything up, and same if its not working at all, it will throw everything out.
    Are you running an aftermarket ECU? What was the aftermarket TPS for? Maybe the wiring had been altered to match?
    Porting the TB will have so little effect on power/torque, I wouldn't worry too much, if the old one works then fine, plenty of other things to do that will have far more benefit.
    so you mean the idle switch? if so, what about the throttle position sensor, have you tested that
  5. new2gti New Member
    haven’t tested the throttle position sensor only the micro switch which is good
    I did check check the wiring as a new plug was fitted for the micro switch and all good there
    thanks for the reply’s
    yeah I'd say the tps has probably gone then :)
  7. Toyotec
    If the car does not start, replace the throttle body with the old one. Start the car. If the engine fires up, good.
    Remove the TPS and fit to the target throttle body with the porting.
    Start the car. If it starts all good. Adjust the idle cam that has the throttle switch for idle. You want to adjust this, so that after a blip, the engine deaccelerates in a dashpot then come finally settles to ~ 800 to 900 rpm if on a Digifant 3.x ECU.
  8. new2gti New Member
    thanks for all the replies
    in the end it was a broken wire on the coolant temp sensor
    when I first swapped the tb’s over all seemed good but after a short drive the following day it was back to running rough
    swapping the tb’s over must of moved the wire so there was some connection there [8-}]
    broken wire sorted and ported tb is on and running sweet
    thanks all
  9. Toyotec
    Excellent.
    Rule of thumb.
    ABFs either work or do not. If they do not, retrace your work steps [:D].
