problems driving/idling?!?!? HELP!!!!!
Discussion in 'VR5, VR6 & Wx' started by Nevdawgg, Jul 19, 2014.
  1. Nevdawgg New Member
    Okay to start i have a 2001 vw gti vr6 12v. it was running fine one day then the next i start it and the idle bounces a little and if i rev or take it out of gear to stop while driving, it will shut off on me.. these are the codes it is throwing at me.....
    P0445 Evap emisiion system purge control valve circuit: shorted.
    P1472 Evap emission control leak detection pump circuit: short to ground.
    P0418 Secondary air injection system switching valve a circuit malfunction.
    P0414 Secondary air injection system switching valve circuit -N112: shorted
    P0037 H02S Heater control circuit : bank 1 sensor 2: low
    P0102 MAF circuit G-70 : low input
    P0031 H02S Heater control circuit bank1 sensor 1: low
    I just installed new MAF, and a downstream o2 sensor.
    please help me and asap!!!!
  2. Collie Forum Junkie
    Adlington Lancs
    have you checked the wiring? could have rubbed through with all those codes
  3. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    Strange one. All that is connected in the same area so check wiring.
    My first test would be to check the fuses in the fusebox in the engine bay.
  4. Nevdawgg New Member
    i think they are okay but ill check it out and let ya know how it goes...
    Ohh and sorry i almost forgot but when it shuts itself down i smell raw fuel but i cant seem to find where it comes from...?
  5. Nevdawgg New Member
    Okay so i checked the fuses under the hood first and found nothing they all look good other than a tiny bit of corrosion, after that i checked the fuses inside the car and found one blown, no descripsion of what it was just a pic of the CEL, i replaced it and the car seem like it doesnt want to shut off on me anymore. Yay!
    Now the only codes showing all the ones above but the MAF. Any ideas to fix these will be appreciated, thanks peeps...
  6. Nevdawgg New Member
    i was wrong it still runs like ****! it was just trying to trick me ):
    someone please help me asap!!!
  7. Nevdawgg New Member
    Someone please help!!! Im way to poor to take it to a garage );
  8. Nevdawgg New Member
    mother ****ing piece of ****ing **** god dammit help me aalreaady
  9. Collie Forum Junkie
    Adlington Lancs
    so have you checked the wiring yet
  10. Nevdawgg New Member
    Yes it all seems to be intact...
  11. Collie Forum Junkie
    Adlington Lancs
    continuity checks?
