Problems Starting...1.8t!
Discussion in '1.8 & 1.8T' started by Funkyfin2000, Aug 31, 2005.
  1. Funkyfin2000 Forum Addict
    Stafford, United Kingdom
    Hi All,
    Mates got an A3 1.8t 180bhp, and lately its been having random starting problems...
    basically, it turns over fine but doesn't fire up......then eventually after about 30 secs it kicks in fine and you get a ton of smoke out the exhaust and the smell of petrol...
    any ideas what this might be???
    It normally happens after the car has been warm, but can happen from cold I believe....he said it was also scanning the revs a couple of times, going up to 2k then dropping and hunting a bit...if that has anything to do with it..
    any help appreciated...
    Rich
    Edited by: Funkyfin2000
  2. Mk1dubzter Forum Member
    First things first, get the car checked on vag-com for any faults or codes. I can do that for you but depends where you are as am in Croydon,Surrey
    Hope this helps
    Vinesh
  3. Funkyfin2000 Forum Addict
    yeah gonna get that done next week and a full cam belt service too...
    done about 70k basically...
    Could it be the coil packs...
    its a W reg, can'#t remember engine code..
    any hints what it could be?
    fuel filter?
  4. philip walker Forum Member
    Pembrokeshire
    As above get the fault codes read.
    Sounds like the coolant temp sender, maybe the throttle body??
  5. Mike_H Forum Addict
    If you've got to fill it full of fuel to get it to start, it sounds like the cold start isn't working. As Philip suggests, I'd assume that's done with a temp sensor on those, via the ECU.
    Plugs, leads etc all worth a check too. I guess it won't have a dizzy on that model.
  6. Torquey Forum Member
    I am having similar problems with my 2.0 Bora but normally only when I have had A/C on. Took it back to garage (non VW) under warrenty and they couldn't find owt wrong. Going back and forwards now and they wont send it to a VW garage so might just give up and take it myself then take it back and tell them whats wrong.
  7. Funkyfin2000 Forum Addict
    Interesting...
    he doesn't need the car full of fuel to have the problem, it happens whenever.....
    he has a dicky temp guage that only works randomly on the clocks....maybe something to do with it maybe??
  8. philip walker Forum Member
    Pembrokeshire
    The symptoms you have suggest the coolant sender
    The coolant senders are a very common fault on all recent VW/Audis, changed loads
    Fairly cheap and easy to fix around 30
  9. Funkyfin2000 Forum Addict
    Alot of people have said the sender..
    i can't see how a coolant or temp sender could cause non starting myself...anyone care to explain?
    Cheers so far for your help guys!
  10. Guests Banned
    Will be coil packs or an air leak in a vacuum pipe......also check the fault codes for the lambda probe....if it is doing this alot it may have fecked the CAT...
    Edited by: Slapbladder
  11. Mk1dubzter Forum Member
    Hello FK
    Thetemperature sender on these engines works by allowing extra fuel to be added on cold satrt up like a thermoswitch on K Jet engines. If the sender is not functioning within its limits it will fail and canbe a cause of the problem-not necessarily the only fault though.
    Get it checked
    Regards
    Vinesh
  12. Funkyfin2000 Forum Addict
    Cheers guys thats great......
    is the sender you are talking about the same one that feeds the temp sender on the dials on the dash?
    Will get it checked out asap and let him know!
