The windscreen washer switch on the stalk of my '92 Rivage has started to work only intermittently. Also, the "flash" switch on the left hand side has never worked properly - it only clicks on to full beam. Does anyone know if there's an easy solution to this? I don't really want to start messing around with replacing the stalk and its MFI switch etc.
You need a new wiper stalk, and a new headlight switch. You might need a new indicator/dip stalk as well. Either that or the wiring is in a big mess. Simon.
