pug 306 coilpack & standalone Q
Discussion in 'Electrical' started by DGT, Dec 5, 2011.
  1. rubjonny
    sorted :thumbup:
  2. DGT
    DGT Forum Member
    The Highlands
    just one more thing pleease
    is this correct wiring for the relay?
  3. brutalmk2-16v Forum Member
    Manchester
    Did you pick up the suppressor? what's the price for that thing?
  4. brutalmk2-16v Forum Member
    Manchester
    sorry double post
  5. rubjonny
    that doesnt really show the socket pins, this is std automotive relay wiring:
    30 - 12v input
    85 - earth
    87 - output to ecu
    86 - ign live
  6. Toyotec
    KL87 - switched live to consumer
    KL30 - Battery supply
    KL86 - Relay coil ign +ve
    KL85 - Relay coil gnd
  7. DGT
    DGT Forum Member
    The Highlands
    ahhhh gotcha..learning all the time on here
    thanks for that rubjonny& Toyo :thumbup:
    brutalmk2-16v. supressor was 4 :)
  8. brutalmk2-16v Forum Member
    Manchester
    That's good if you know that only scrapyards MAY have this part
  9. DGT
    DGT Forum Member
    The Highlands
    ive hit a brick wall here :(
    ive blown 2 fuses on the fuel pump/injector supply (20 amp)
    the coil is making random cracking noises and the supply wire is warming up..not excessively though
    any ideas, as ever , greatly appreciated
  10. rubjonny
    what exactly are you running off the pump/injector line? could it be those resoistors are just pulling too much load for a 20a
  11. DGT
    DGT Forum Member
    The Highlands
    hi again rubjonny.:)
    im running a pump from a mk1 gti, an in tank lift pump and weber low impedance injectors..
    ive just been told (reminded) that the K6 ECU is setup to run conventional spark out of the box and im setup for wasted so i have to send it back, hopefully i havent fried anything, but judging by the weird crackly noised coming from the coil i probably have [:s]
    the other thing..the suppressor is bolted to the head, so not earthed, this shouldnt matter right?
  12. rubjonny
    well if the engine block is earthed properly thats fine, which it must be otherwise the starter motor wouldn't work [:D]
    how does the fuel pump sound? maybe disconnect the wiring from your injectors and bridge relay so pump is running constant, then see if fuse still blows after a similar amount of time. if it does, you know one of the pumps is drawing too much power.
  13. Toyotec
    Replace fuse for FP and Injectors. Remove the ECU connection the injectors and try cranking.
    However if you think that the PCM was not configured with the drivers to run two spark channels this maybe at fault and does indeed require sending back the ECU to base.
  14. DGT
    DGT Forum Member
    The Highlands
    i ran the main pump before fitting and it sounded sweet. i havent ran the lift pump in isolation.
    thanks toyotec..the K6 is getting posted tommorrow
    :thumbup:
  15. DGT
    DGT Forum Member
    The Highlands
    Just had word from Emerald.
    so happy i chose this company, theyve always been extremely helpful.
    considering i bought the ECU 2 years ago i thought this was very good of them:
    :clap: :thumbup:
  16. Toyotec
    I have always had good support from them whenever there was an issue with one of their units. They are indeed very helpful as are the other brands of ECU supplier.
    Keep us posted when it starts :thumbup:
  17. DGT
    DGT Forum Member
    The Highlands
    Will do:)
