Pump Mounting bracket clips????
Discussion in 'K-Jetronic OEM injection' started by Matthew Walker, Oct 8, 2021.
  1. Matthew Walker New Member
    Hi all
    Hope the pictures show (first time trying to post a picture)
    I’m overhauling my K-jet pump and associated parts due to the main pump failing. I have the unit off the car and I noticed that one of the 4 clips that go onto the 4 rubber inserts on the mounting bracket has rusted away.
    Does anyone know if these clips are still available and if they have a part number I’ve searched eBay, heritage parts and classic VW parts with no success.
    If not I was just going to use a washer top and bottom of the rubber insert.
    FIA
    12642F7F-5A4B-4524-AEC3-1E0D14CE4A60.jpeg F8605212-4641-42B2-8995-67499018F338.jpeg
  2. costel1969
  3. Matthew Walker New Member
    hi costel1969
    I’m not sure what you mean?
    if your referring to the part number on the other items I already have them ready to fit. It was just the clips that I need to replace and unfortunately them don’t have any part numbers stamped on them.
    Thanks for you help though.
  4. Tristan
  5. Matthew Walker New Member
    Tristan likes this.
    tbh you can get away with 2, the main feature of them is they bite onto the threads so you can shove the pump up there and it doesnt fall back off onto your face while you get the nuts done up. other 2 can be fitted with washers
  7. Matthew Walker New Member
  8. Matthew Walker New Member
    thanks mate I’ll just fit the 3 I have then
    Today didn’t go quite to plan ive fitted the unit in and after a could off leaks that I fixed I’ve ended breaking the meta outlet pipe from the filter just above the banjo connection.
    don’t suppose you know if you can get a replacement pipe? Or will will I have to try and make something up?
  9. Matthew Walker New Member
  10. rubjonny
  11. Matthew Walker New Member
    Hi Rubjonny
    Thank you for this. They have the part I need but unfortunately it’s discontinued now with by the manufacturer. Looks like I’ll have to see if there anywhere local to me that can copy the one I damaged.
  12. rubjonny
    thats a shame, could try local hydraulics place
  13. Matthew Walker New Member
    I know it’s just my luck. I live in Manchester and have spoke to a company called HTS and they can make me one up god know what it will cost though [:[][:[]
