16v KR I'm left with 2 level sensors and 2 unconnected wires. Which one goes where? One is red/white - brown Second is red/blue -brown
I think it is a CE2 cluster, looking at the wire colors: http://www.a2resource.com/electrical/CE2.html
I was running into the same problem Weird thing is, these are factory cables. They haven't been tampered with. So I have no clue why these don't show up on the CE1 overview
red/white and brown/white is outside air temp sensor for MFA, it runs under the battery, thru a hole in the inner wing then to sensor clipped inside wing level with the bumper red/blue and brown is coolant level sensor
the reason these dont show on the fusebox pinout lists is they dont go to the fusebox. outside air temp connects to a plug on dash loom, coolant level connects to coolant level warning control relay 42 or 43 clipped above fusebox
