R32 engine help
Discussion in 'VR5, VR6 & Wx' started by lutherlee, May 9, 2015.
  1. rubjonny
    oh well that scuppers that idea!
  2. MUSHY 16V
    aberdeen
    Can the vvt map be altered to suite the more advance of the BUB engine
    I have both of most of the parts other than the mk5 ECU
  3. Toyotec
    Have not compared files from the two variants as yet.
  4. lutherlee New Member
    Thanks. I'll try to get hold of them as it's all a bit over my had if I'm honest. I know the cam sensors are in place but the top of the engine is from the old one as it still has the old engine number on it lol. I need to speak to the previous owner so as soon as I getvthe the log book ill write him a letter pr do a bit of Facebook stalking ha ha
    Thanks everyone :thumbup:
    1990 likes this.
  5. MUSHY 16V
    aberdeen
    Maybe a job for the future
  6. lutherlee New Member
    Spoke to Andyout. It is the cam and sprockets that need changing. Better get a lottery ticket this weekend lol
  7. MUSHY 16V
    aberdeen
    One of the cams is the same but can't remember which one
    The sprockets are over 300 each
    Could be worse I guess
  8. lutherlee New Member
    How many sprockets are there pal?
  9. MUSHY 16V
    aberdeen
    if it has the mk4 head it may have the cams and vvt adjuster sprockets as well
    think you need to find out what exactly was done
    you don't want to buy parts you don't need to
    you have two vvt cam sprockets at over 300 each this is why most people don't change them while doing the chains even though you are meant to
    you also have two more sprockets that are only a few quid two chains and the five guides and tensioner that would be say another 250ish
  10. lutherlee New Member
    Trying to get in touch with the previous owner as I don't want to mither the garage who looked after it. Not got the log book yet so I may have to call them again lol. Cars from Whitehaven which is light years away from me lol
  11. lutherlee New Member
    Spoken to the garage in Cumbria and sprockets and sensors where swapped over.
    Been to a vag specialist and the code is 17755, he thinks its the chain or tensioners. The bloke up in Cumbria is adamant the chain ect was fine when fitted and the light as always been on. I guess time and money will find out lol
  12. Toyotec
    Fault 17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incorrect Correlation.
    Possible Causes
    • Timing Belt/Chain incorrectly installed
      • Timing Chain probably lengthened
    • Camshaft Position Sensor 2 (G163) faulty
    • Engine Speed Sensor (G28) faulty
    Possible Solutions
    • Check Timing Belt/Chain installation
      • Use Measuring Value Blocks (MVB) to Check Timing Chain
    • Check/Replace Camshaft Position Sensor 2 (G163)
    • Check/Replace Engine Speed Sensor (G28)
    Taken from >>here<<
  13. lutherlee New Member
    Votex in Congleton did the diagnostic and want to do the chain for 1500-2000. The car is under a 3 month warranty so waiting on a call back from the garage I bought it from. The car runs fine and there is no strange noises coming from the engine, the garage from Whitehaven told me all the relavent parts were swapped over and the chain was in perfect condition. The bub was low mileage and the light came on straight away, maybe they didn't fit it correctly? I feel lost if I'm honest and the whole situation has ruined getting my dream car, but I suppose that's life. If I get the chain done and the light stays on at least I don't have to worry about it going on me.
  14. lutherlee New Member
    Hopefully its panic over. Had it on vagcom and block 208 is 5 and 209 isn't showing at all. Hopefully this means its a sensory problem, or is someone going to crush me? ha ha
  15. MUSHY 16V
    aberdeen
    not convinced as this was what happened when my friends r32 when the chains went
    only the one cam showed up even after a sensor was changed his was on the mid 50k
    it's not uncommon for them to be a tooth out
    if it's under warranty I wouldn't mess about
  16. lutherlee New Member
    If the chain was that badly stretched that the sensor wasn't picking up the chain wouldn't it be noisy? Which sensor picks up block 209?
  17. MUSHY 16V
    aberdeen
    209 should be the exhaust
    some are noisy others are not
    some can be noisy and the fig are good
    is it noisy?
    could be it was not done right in the first place and it's out a tooth not unheard of even from new but rare
  18. lutherlee New Member
    No I wouldn't describe it as noisy at all pal
  19. lutherlee New Member
    Got Gaz at vag auto care services on the case. Managed to get my hands on the 2 cam pulleys, cam sensors and casing to hopefully get this light off. He's also doing a full service and Haldex service. Then I can get coil overs, exhaust and remap sorted. Cheers for all your input guys ????
  20. MUSHY 16V
    aberdeen
    Aye Gaz is a top bloke
