Rear axle bush tools-request for help
Discussion in 'Mk3' started by swisstony, Jun 4, 2019.
  1. swisstony New Member
    I have been reading up on this and aside from being a complete bastard of a job (which is true so far) I need some help if possible.
    So the idea was to replace the existing rear axle that is on the car now with a cleaned up, painted and new bushes one . This is what we started with, nice !!!
    So with a combination of flappy wheel, wire wheels, sandpaper, ginders etc, you get to this
    So some of the hard work has been done by basically whacking the hell out of the old bushes to get them off. air saw, chisel and you get these
    Will clean up the surfaces on the inside with sandpaper and die grinder to get it all smooth. Now this is where we need some help. There are kits available online to buy but they are £40 ! and this will be a one time job, I doubt I will be using it again well not for the next few years so instead of buying, has any kind person in here got one we can borrow. I am looking at these kits
    https://www.ebay.co.uk/itm/263429037545
    https://www.gm-tools.eu/2680,rear-a...-vw-golf-iii-mk3-passat-35i-vento-puller.html
    If you do, I am happy to pay for shipping just so we can complete this job and then send it straight back.
    seen it done with threaded bar and steel plates/sockets if you want a cheaper route. just need offcuts to pack out the bush on the curved side a bit. or bypass all that pain and go poly bushes instead, push right in. people who have done it seem to have no issues with them :)
  3. swisstony New Member
    Yes could go poly route but already purchased the topran bushes so we are committed to going this route. Dont really want to bodge it with packing material so was hoping some kind soul has done this before and has the installer tool kicking around his garage :) But might have to buy the set, use it and then sell it.
  4. swisstony New Member
    Actually thinking about it, maybe an idea is to sell the topran bushes we have and go poly route as you suggested as these are the same price as that removal tool links I posted
    https://www.ebay.co.uk/itm/372063450553?ul_noapp=true
    are these any good ? anyone had experience of them
  5. rubjonny
    they look good. make sure its the mk3 ones you need though, as some early mk3 had mk2 bushes which are a bit smaller.
    and a tool is only a bodge if it doesnt work or damages the bush ;)
  6. swisstony New Member
    oh bugger, how do I know what size I have ?
  7. rubjonny
    measure the diameter ofp the new bushes you bought and see if they actually fit your beam :)
    off the top of my head I think mk2 are 45mm and mk3 are 55mm, you'll want to double check that though!
  8. swisstony New Member
    we have the later mk3 so just checked and it looks like 55mm so think we are golden. Thanks for your advice , will just sell these topran ones as I doubt we can send them back now being purchased weeks ago. will clean up the inside bores of the axle and fit these when they turn up
  9. Farmerchris
    Farmerchris Paid Member Paid Member
    I have a home made tool you can have asking as you to cover postage? It worked well fro my MK2 bushes
  10. swisstony New Member
    thank you very much for the offer but in hindsight and advice, have gone full poly bush route. Far less hassle we hope :)
