Rear Top mounts
Discussion in 'Chassis' started by AndyD, Oct 28, 2003.
  1. AndyD Forum Member
    I'm going to be fitting coilovers soon, and have got some uprated front top mounts ready, but I cant seem to find any rear ones - is it worth just changing the worn ones for new standard ones? Anyone know where I can get some from - VAG/ECP/GSF etc.
    Ta
  2. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    My MK3 had 78k on the clock when I fitted coilovers. The rear mounts were still like new so I didn't bother replacing them. Depends how old/what mileage your car is.
    GSF didn't do the rears for mine so it was going to be a main stealer job anyway.
  3. GVK
    I've got the Prothane top mounts on my car. Got them in a GSF kit, but I think you can buy them seperatley from Big Boys Toyz
    excuse the dust!
    Edited by: G_V_K
  4. fionn Forum Member
    Ireland
    Do the poly top mounts make it a lot harsher / noieser?
    I've heard some lads say that using poly top mounts is harsh on the shocks & can shorten their lifetime - any truth in this rumour?
  5. KeithMac Forum Junkie
    Kazakhstan
    If you`ve got coilovers on they take a lot more stick than the rubber items.
  6. Andy99 Forum Member
    they really sharpened up the ride when i fitted them to my golf. much better turn in.
    have you noticed a difference Gary?
  7. AndrewD Forum Member
    Note sure, but I remember readig something on VWvortex about poly rear top-mounts not allowing the damper to pivot enough causing damage to the damper unit.
    Will have a search later today if I get some time and get back to you ... :)
  8. barny Forum Member
    Lost in Glos
    fine on mine !
  9. fionn Forum Member
    Ireland
    "on VWvortex about poly rear top-mounts not allowing the damper to pivot enough causing damage to the damper unit. "
    Yes I think I read that there too.
  10. damogti Forum Junkie
    Chichester - West Sussex
    I've heard that they make little difference compared to replacing the old ones with standard new VAG items....
