Is there no other way to remove the shear bolts other than drilling the heads off?.Once they are drilled how do you get the remnants out to replace for new bolts
i gave em a quick whack with a hammer and small chisel , once you moved em a bit they come out ok wasnt as bad as i expected
i struggled with these on mine, in the end i got mole grips on the threads poking out the top and cracked em loose that way. you can unbolt the bit those screws go into from the car and pull the whole thing out, that gives better access to attack the bolts.
