Hi Guys I've been having some electrical issues and relays are blowing and I'm suspecting the connections inside the fusebox. When we pull out some relays they are quite green and corroded. How do I remove the front cover to clean all the contacts inside? The fusebox is out and will be in the workshop. I would like it like this https://flic.kr/p/2oexPDc Cheers
Got the cover off. Basically lots of plastic tabs. Also found the issue to why the horn isn’t working. Need a new fuse board. https://flic.kr/p/2oex9Bm One of the metal contacts has corroded and broken.
