repairing mk2 golf rear light cluster
Discussion in 'Styling, Trim and Bodywork' started by saladman, Jun 18, 2023.
  1. saladman
    saladman Paid Member Paid Member
    West Yorkshire
    Just bought a set of blue rear clusters which were cheap (ish) because the black plastic surround is damaged.
    I was hoping to swap the lenses over to a good plastic surround from another set but after a bit of gentle prying / looking I'm not convinced it's possible or sensible. Has anyone done similar or know how the coloured lens parts are attached to the black part?
    Now considering patching with bits from another cluster - there's some videos around of people using soldering irons to melt / 'weld' plastic parts together then smoothing over with filler. I'm sure the smell and acrid smoke is very healthy.
    Any tips or guidance welcomed [:o)]
  2. pigbladder Forum Addict
    cambridge , uk
    yes i would try and plastic weld or glue in a bit from a scrap light ...smooth it down and texture spray the area
  3. saladman
    West Yorkshire
    agreed, going to practice on some other parts to start with
    any idea what plastic the black part is?
  4. PhilRyder
    You will get a good result with superglue (activator will be helpful here). Then you can simply use filler and paint.
    saladman likes this.
