Replacement pipe, where to find?
Discussion in 'Mk2' started by trmorgan95, Sep 12, 2015.
  1. trmorgan95 New Member
    Evening, i have recently noticed a crack in one of the engine bay pipes going from the main block into the dash for the heater matrix, im having trouble finding it and was wondering if anyone knows the part name or has one spare? the pipe is wider on the end at the block and smaller going into the fitting for the dash. i'm unsure if the part is from a MK3 golf or a MK2 golf as the engine is a 2.0 from a MK3. see picture.
    cheers!
  2. MUSHY 16V
    aberdeen
    for a mk2 it should be 191819371E and by the looks of it that is the one you have
    it will come too long as it's been cut to add that valve in that was part of a recall
  3. trmorgan95 New Member
    wow, that was quick! thank you very much mate i'll get one ordered and trim it down!
    I'm using mk3 hoses in mine, straight fit and route nicer. plus they are uncut so can be used to delete the bypass valves once you replace the matrix with a new mk3/4 unit
  5. MUSHY 16V
    aberdeen
    mk2 one should be uncut as well as so he could do away with the valve
    the one l list is the return
    small block mk2 use a mk3 return 1H0819373A so don't doubt that other mk3 ones fit
    aye if you get new mk2 ones they be uncut, but if scrappy hunting you'll find more mk3s plus they wont be cut :)
    MUSHY 16V likes this.
  7. MUSHY 16V
    aberdeen
    which is handy :thumbup:
  8. rubjonny
    plus you're saving the planet ;)
  9. jojo
    jojo Paid Member Paid Member
    Solihull
    Running a mk2 and saving the planet?! Lol lol
  10. rubjonny
    of course! think about how much co it takes to build a modern car, and make new parts. recycling is good for everyone. and dont get me started on any hybrid or purely electric car 'it produces no co!' eesh
  11. MUSHY 16V
    aberdeen
    The average modern car uses the same amount is co2 in 60 to 80k as it dose to make it in the first place
    The more you recycling that the better I guess
