Replacing bushes in MK3 02A shifter?
Discussion in 'Transmission' started by G60Dub, Sep 16, 2009.
  1. PhatVR6 Forum Junkie
    You're still "rolling it in glitter"....the box syncro's don't like to be rushed, and the 02A mechanism is complete pants too. You'd be much better of buying a CAE shifter or something.
  2. pigbladder Forum Addict
    cambridge , uk
    yeah phat your not wrong...i made them bits for a couple of quid
    i havent got loads to spend on it ...id prob get a mk4 tower and shifter if i had the funds
    for what its cost its turned it from poor to acceptable imo
  3. PhatVR6 Forum Junkie
    I'm all for getting rid of the slop and rubber bushes actually, it's just anything with a short shift, just doesn't work on an 02A, the box doesn't like it.
    Also look at your engine mounts, you'd be amazed at how much engine movement affects gear shifting.
  4. pigbladder Forum Addict
    cambridge , uk
    its only shortening the side to side movent ...im not expecting it change gear like lightening
    i made mine so it can be standard movement too
  5. Hotgolf
    Smelly Cornelly
    Righty a couple of pics.
    As I said though, my first lever was wrong due to the lack of adjustment, where as this now has an 8m stainless allen head one end to allow the pin to rotate, and I added a stainless nyloc on the other end to hold things tight( although it's not really needed as I've retained the flats on the end of the pin, which buts up against the lever) but it can be altered to take up any slack if required.
    Just to add, the nyloc on the lower pin doesn't need to be undone to adjust the lever, only the allen head bolt as to make things a little easier.
    The main plate is stainless, and the pins are ground EN19 bright bar.
    The arm has 2 threaded holes to allow you to use either a short throw or std. throw. To use the std throw an 8mm allen head bolt will be needed to go underneath the pin to hold the to plates together.
    The top pin for the cable has a 3mm hole in the larger diameter to put an allenkey through to hold it when tightening.
    So here it is:
    I'm in 2 minds wether to drill the 6mm pin for the cable to put an R clip in, or to cut a groove to put a C clip in. Probably depend on what I have to hand.
    As for the crappy plastic block. Having looked at the slightly different style of tower(the one that can't use the weighted lever) the plastc is replaced with a square block. After having a good look I may have an idea of what to fit in there, that will take up all slack/slop, plus give a crisp, smooth action. I'll have to have a play first. If that fails though, it's easy to replace the plastic block with a similar alloy block. But I'll be looking into it :)
  6. pigbladder Forum Addict
    cambridge , uk
    thanks for the pics
    keep us updated if you think of a fix for the plastic guide bit
  7. Ess Three Forum Member
    Aberdeenshire, UK.
    Nice work there Mart...
    Good effort!
    A hole will be easier...a washer + R clip or split pin that way - which most people will probably habe to hand.
    I always loose small C clips. Probably my sausage fingers at fault there.
    Interesting... :thumbup:
    Keep us updated. And put me down for one when complete :thumbup:
  8. Dennis10
    Dennis10 Forum Member
    Tring
    ME TOO!!! What I mean is, please may I purchase one when you've nailed the design! Anything to help the terrible 02a gearchange :thumbup:
    Top banana!
  9. G60Dub
    G60Dub Forum Member
    Angus
    Put me down for one too Mart.
  10. G60Dub
    G60Dub Forum Member
    Angus
    Any updates Mart? :)
  11. G60Dub
    G60Dub Forum Member
    Angus
    Bump on Mart updates!
  12. Dennis10
    Tring
    BUMP for updates?! [:$]
  13. Hotgolf
    Smelly Cornelly
    Got a couple I need to finish off, shouldn't be a few dyas but I'm slammed out with a few nox rebuilds etc.
    PM me lads, keep it off here if possible(delete the posts if you can juts to tidy it up a bit)
  14. Dennis10
    Tring
    PM'd you the other day mate! :) Im desperate for one of these babies!
