Retro fitted mirrors, will they be fused?
Discussion in 'Electrical' started by Rustbuster, Apr 1, 2023.
  1. Rustbuster
    Thanks all for advise I’ve been reading here about retro fitting powered mirrors to my CE2 MK2 16V. Thought I had while connecting the power to these is will they be automatically covered by a fuse? I wired the live to connector “D” pin3 which was vacant. The live for the heat to connector “P” pin3 which is also pretty the rear de-mister. My assumption is that because this goes through the fuse box, if, in future there’s a short these will be protected by fuses but just want to check, if anyone knows? Cheers.
  3. Rustbuster
    RJ, thanks for those links. I put the mirrors on Pin3 of block D and as per your list pulled fuse #4 and that killed the circuit. Many thanks messiah..
    no problem glad you're sorted :thumbup:
