I've got a Full Mk1 Gti roll cage with Doorbars...I'm gonna put it on eBay but what sort of reserve should I put on it?... Whats the second hand value of these things? O...its Saftey Devices(Fixed diag) if that helps? Cheers Phil
Well this isn't a for sale post. I've just tried to put one up and it won't let me...I'm not a club GTi member anymore.
Bolts and clamps, main joins are welded, you bolt the front cage to the rear, the door bars bolt on and the front top bolts across. Edited by: Ph!l_H
Mike, the bolt in cage is pre formed to fit whatever car it's designed for. When fitting a bolt in cage, usually it will require welding in some plates or brackets into the floor/structure of the shell to bolt the cage too.
Here's a pic - good illustrations of a bolt in cage and the plates/brackets I mentioned above. Safety Devices 6 point bolt in cage SD cages As for price, same thing for a mk2 was advertised on here last week for 195 + delivery and sold the first or second day it was up.. missed it!! Edited by: GVK
Saftey devices cage + 2 door bars costs 360 + Delivery. Thats the best I could find. I think I'm gonna try for 200 and see how it goes.
