rumbling and clonking from 1.6 driver
Discussion in 'Chassis' started by mark25, Nov 13, 2003.
  1. mark25 Forum Junkie
    all,
    my 1.6 driver with 180K on the clock has started rumbling at over 40 mph, also there's a clonking on slow turns. there does not seem to be any fault that fits this description in the haynes manual. any ideas? i'm thinking cv joints, but it does not fit the haynes description of excesive play on acceleration and decceleration!
    thanks in advance Mark
  2. Jettin' Forum Member
    Have a look in the FAQ section, there are posts about how to tell if its CV or bearings that need replacing
  3. Drew21 Forum Member
    test for cv is to put it full lock and then drive forward and back again without using brakes ie using the engine to change direction
    listen for horrible sounds[:s]
    rumbling could be bearings or cvs or some thing else???
  4. mk2driva Forum Member
    from experience with mine the wheel bearings made a whiring noise and when doing slow turns it was the wishbone and bushes that were shot hence the noise. replacing them solved my clunking anyway.
