finnaly got my vr6 conversion started after 4 months of building it up but i noticed straight away that it had a bad misfire. i felt the exhaust manifold pipes and you could tell that cylinders 1 and 3 are not firing as it was cold compared to the others. i pulled out the spark plugs 1 and 3 and they are still clean and i pulled out spark plug 2 and you can see blackness from when it was running so cylinder 2 is fine. the engine block is new with a full set of new pistons rings ect. it is an obd1 engine and i followed a guide for the firing order and have since then re checked it. when building the engine i put in new spark plugs and a new dizzy cap. im thinking the leads maybe knackered but i havent tested it yet to see if im getting a good enough spark. ive ordered a full new set of leads to be sure as the ones i have arent the best condition anyways. also i have a rotor arm on the way too. if non of these seem to work what should i then look at doing. test power at injectors 1 and 3 flow test them with the rest to see how they perform against each other. compression test. but i would of thought a new engine will be at the best it can be. is there anything else that could couse a misfire. ecu? any help is greatly appreciated
ive had it running for about 30 seconds i would have thought it would have sorted out by now, theyre not noisy or anything engine is smooth as in no knocks or metalic noises just a bad misfire. ill keep it in mind. i didnt think about that cheers
not a 100% sure i cant remember. they were wet as i wiped them clean again. i tried to smell it but its a bit hard to tell when you have a blocked nose! ill thinking ignition side of things which im hoping but i think i might whip all the injectors out and test them all to make sure they are fueling the same cheers
yeah thats what im thinking, im going to try it tomorrow. i think unplugging each injector will be a bit hard though because of the inlet manifold covers them.
a compression test would prove that would it? i hope it isnt its the original tappets and i had some oil in them (new oil)
well ill take it from you that it will sort itself out then and hopefully i dont have to strip it down again! if thats the problem. going to test it all tomorrow so i will reply back on here on what i find cheers mate
Got it sorted. Not 100% sure what it was as this time I fired it up it sounded much better. Still with one cylinder down. The exhaust was still cold on cylinder 1 after some messing about and testing it started to run right and all exhaust pipes warmed up the same. And it sounds like a proper vr.
My money is still on that tappets hadn`t filled with oil, glad its sorted its so tense when you start a engine for the first time so much going through your mind! have i done this or this lol
