Hi, a couple of my bolts on the rear brakes Of my mk1 are past their best.they are the tiny ones that bolt though the backing plate in to brake cylinders.just need to know what thread size they are.thanks. Been doing a bit if a brake overhaul as never really been done.fronts are better now.
Thanks.just a another quick one dont matter if I get no response. My accumulator is shot and so are the lines Do you or anyone know the union size of two Fittings onto accumulator. Mine is a mess but I can buy bent tails cheap If I know the sizes.
I've used gas line fittings before, for a 17mm outer nut it's usually an m14 x 1.5 nut. On an 8mm OD Pipe.
Yes gonna make up my own as PRE-MADE with the banjo,s are like £70 a piece I'm not tight but not paying 140quid for two lines lol Make my own for £20. There is 2 sizes on the accumulater though. Inner one is smaller.
This is the kind of thing I have used. As it happens, part of my work is gas fitting. Wurth do the same type of fitting, for pneumatic lines.
