Hopefully someone on here can help, I'm looking to replace my garage door, its a single up and over door 230cm wide 197cm high. Current one is metal, best to stick with that or are there plastic/composite ones available now? Any particular makes to go for and what sort of price will i be looking at for on fitted? Cheers
Thanks, will check out Hormann doors, The garage is in a block with no power, i'd like some sort of basic lighting in there. Are there any decent battery powered lights available that can be bolted to the wall/roof?
50/70 genny, power tools and lights sorted. Loads on Ebay. Even B&q sell them, though well marked up.
Cheers, Just looking for some lights really so i can see when parking the car in there at night, no work will get done in this garage.
A decent torch or LED worklamp? Presumably you're going to be able to use the car's lights until you turn the engine off. http://www.sourcingmap.com/wireless...gle&utm_medium=froogle&utm_campaign=ukfroogle Never used them, but I'd guess that's the type of thing you're after?
