slipping fan belt
Discussion in 'Mk2' started by copeidge, Jan 19, 2010.
  1. copeidge
    copeidge Forum Member
    hi guys, got a bit of an issue tbh, i recently changed my fan belt as the old one slipped abit and it didn't change when i tightened it up.
    the new one will slip for around 3 seconds when started then if i rev over 2k ish it stops or stops on it own after about 5 seconds, ive tightened the belt and there is abit of slack but nothing major at all. and i don't want to tighten it too much so that i bugger my water pump bearings
    any suggestions?
  2. Jolfa
    Jolfa Forum Junkie
    Queenstown - New Zealand
    Just tighten it up, I always do mine 'til it whines then when I get bored of/concerened about it sounding like a supercharger slacken it off abit. Never had any problems :)
  3. gtijon Forum Member
    England
    Are all the adjustment bits that should be there, there? On mine someone had meddled with it, and it could never be made to hold. A few new bits for the adjuster from the scrappy and it was sorted.
  4. Devon Dubber
    Devon Dubber Forum Member
    Perhaps clean the wheels up so they don't have any old rubber and crud on them... just an idea.
  5. copeidge
    will give these idea a shot tomorrow cheers,
    how do i know when its too tight?
  6. shaz8389
    shaz8389 Forum Junkie
    You should have a little play, the haynes tells you the play (I think it's actually right) I'd check for you but mine's in the garage because it's really good for leaving stuff on top of.
    Think it's 4-5mm
  7. Jolfa
    Jolfa Forum Junkie
    General rule of thumb with belts, you should be able to twist them 90 degrees, no more. When it whines it's too tight, if it squeels it's too loose :)
  8. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Mk2 fans are belt driven are they?... ;) :lol:
  9. copeidge
    still called a fan belt.. isn't it..??
    cheers jolfa that make sense! think the alternator is a bit tight on the lower bracket so had the attack it with a rubber mallet! got there eventually!
    now sorted cheers.[:D] :thumbup:
  10. oldskooldub Forum Member
    Manchester
    Don't forget to slacken thelower bolt off;)
