Smoke Leak Testing is now available from Badger5 SMOKE CHECK starts from 65+vat Identifies leaks in pressure and vacuum system. We all know how vag cars breed vac leaks! Biggest common fault we see with running problems, lumpy idles, fueling adaption errors in over 60% instance are caused by something leaking in the vacuum or pressure pipes. With this equipment we can now fully test the system for leaks. UV dye residue to find the tough to see leaks. SMOKE UV SMOKE/TRACER DYE
