the floor in the back (drivers side) is absolutely soaked...... is this a leak problem or something just washed the car, but i haven't really sat in the back before to notice, the mats were down.....
I would says it's definitely a leak, unless you were hosing down the seats or something!! Umm... Window seals? Top of the Tailgate? Hole in the floor? Lifted the carpets in mine the other week, and there's wet on the drivers side under the carpet in the front, uh oh...
Check the drain holes in the sunroof (if you have one) and also under the bonnet, up near the bulkhead.... stick a wire coathanger down into them, then water should flow.... used to happen in my Scirocco, and my ex's Mk2, after poking... all clear!
right just checking, the floor is wet again, wetter than earlier i'd say (dryed it with a towell!) its only the floor not the seats or anything and just the drivers side. the sunroof seems fine. not 100% about the other bits mentioned, any ideas from just the floor? where to check? thanx
Please don't put the words poking and ex in the same sentance , there are childern on this forum after all.
open the door take off the door cards theres a plastic sheet check to make sure thats not teared or ripped that will be where its leaking
nice one altern8! was looking how to get the door card off, and noticed the bottom right hand corner was off a little, put my hand there and the plastic behind is ripped. lined it up and its where the leak is! so just tape or whatever the plastic back down behind the door card?
best best is to check the whole sheet it might be all ripped if thats the case just get a plastic bag from b&Q the long wall paper bags and then stick that over the top of it if u aint sure me and mark will give ya a hand most prob
thanx for the offer, though i was feeling adventerous earlier and fixed it was easy enough when i found out where the hidden screws were
