Hi guys once again av got a electric gremlin with my mk1 golf 1.8 carb cabriolet when a turn the ignition key the green indicator comes on all the time is this a bad earth if so where are all the earth located on the car from fues box to under the bonnet.Many thanks
sounds like you've popped fuse 19 for the indicators, if thats deffo ok pull the hazard switch out carefully and check the black/blue spade hasn't come off the back of pin 15
