Ok the baclight on my speedo isnt working. I dobnt know why it's not working or how to how to find out?? Is it fused under the dash? If it is the bulb how do i change it?
remove radio (one screw behind this, top middle), headlight switch (one screw behind this), middle blanked switch plate on the bottom row (one screw behind this) fan switch and the heater levers, the remove heater facia(behind this are 3 screws, there should be two screws in ine instrument pood remove these to remove the dash surround then to access the clocks there are two screws either side of the instrument pod remove these then the clocks should pivot forward to allow you to accsess the bulbs thes are two little black squares about 5mm across that twist out hope this make sense
