How easy it to replace the standard 16v roof aerial on a mk2 Golf? Parts of the rubber base have broken off, so I was thnking about replacing the whole lot. Anything to watch out for?
Pretty easy, but can be time consuming... You`ll need to drop the headlining at the rear. The best way, so as not to damage it, would be to remove the c-pillar trims (which will need the rear speaker mounts removed first). Then you`ll see the nut that secures the aerial. Remove the old aerial, then make sure the area where the nut/washer contacts the roof is clean, and corrosion free (good contact needed). Fit new aerial, and re-fit headlining and trim pieces. Done!
if its an original aerial,the connector(s) are a very short distance(few cm.)from the base. treat roof-lining carefully-its only made of cardboard.
Thanks, I know you need to be careful with the lining having added a roof aerial to a 8v! I'll investiagte further.
