Standard Springs.
Discussion in 'Chassis' started by Greenmk1, Oct 28, 2003.
  1. Greenmk1 Forum Member
    Can anyone shed any light on the following point.
    If using Koni TAs on my Mk1, is it advisable to have lowered uprated springs, such as Eibach, or is it possible to use standard rate springs.
    The reason I ask, is taht the Koni shocks and the original shocks that I took of the car were the same length, whereas I thought the Konis would have a shorter piston rod.
    For everyday use, the so called 'springs' that was supplied with the kit are way to harsh and the ride is terrible. [:x]
  2. KeithMac Forum Junkie
    Kazakhstan
    You can use normal rate springs with them, lowest you`d want to go would be 40mm (they aren`t designed to go low), I ran my mk2 on vag springs and ta`s, found it better with eibach springs but they are firmer..
  3. fionn Forum Member
    Ireland
    greenmk1 what kind of springs were supplied with the kit?
  4. Greenmk1 Forum Member
    Don't know as they have no markings on them. They were part of the Koni SSK kit and not just a odd set thrown in by the shop.
  5. AndrewD Forum Member
    Think the springs in the Koni SSK kit are made by Voigtland (sp?)
  6. Greenmk1 Forum Member
    Yeah, that name seems to ring a bell.
  7. fionn Forum Member
    Ireland
    I hope the eibachs that came with my koni ta's wont be that stiff on my mk1!
  8. Greenmk1 Forum Member
    Let me know the results so i can decide on what springs to buy ;)
  9. fionn Forum Member
    Ireland
    Will do, could be a while though,half way through the respray atm.
