Starter motor - second opinion needed
Discussion in 'Transmission' started by jmsheahan, May 29, 2018.
  1. jmsheahan CGTI Graphics Designer
    Wiltshire
    Got an issue with the starter on my mk2 was hoping to get a second opinion before splashing out on a new one.
    Mk2 GTI, 8v box and flywheel, Mk3 Golf starter motor.
    Problem seems to have arisen since re-installing my gearbox and a lightened flywheel. Turn the key and the starter clicks but then nothing. Rock the the car back and forth a bit in gear and it engages and fires up. Which indicates to me a solenoid issue and/or the starter not engaging properly with the teeth on the fly?
    Had the starter out and in a vice rigged up to battery. Didn’t seem particularly lazy but its pretty old.
    Seems to be an intermittent problem at the mo but needs dealing with as its fecking annoying lol
    Thanks!
    had the same on our old polo, wqas worse when engien was hot. new 2nd hand starter sorted it :thumbup:
    one test next time it does it jump solenoid with 12v direct from the battery, if it cranks up nice then look at ignition switch and wiring from it
  3. jmsheahan CGTI Graphics Designer
    Wiltshire
    Nice one, thanks RJ :thumbup:
  4. jmsheahan CGTI Graphics Designer
    Wiltshire
    Longshot but can anyone confirm the part number for a Mk3 8v GTI starter (or a diesel one that'll fit an 020 box)...
    Thanks!
  5. pigbladder Forum Addict
    cambridge , uk
    havent painted the starter or box have you ? needs to earth via its flanges
    check the big earth on gearbox is tight and good cond
  6. jmsheahan CGTI Graphics Designer
    Wiltshire
    The box has been painted but the flanges etc are clean and bare metal. Earths are good.
    It's clunking against the flywheel and not engaging, almost like the teeth are worn or there's not enough oomph to fully engage. Rock the car back and forth in gear, it'll line up and fire up. It's especially fun doing this in public places :thumbup::lol:
  7. Farmerchris
    Farmerchris Paid Member Paid Member
    They are pretty straight forward to strip down. Give the solenoid mechanism a good work with a bit of oil and check the sprocket travels up and down the motor shaft freely.
    They get pretty grubby over the years
    I did the above and it was like new
  8. rubjonny
    there are quite a few you can use, but try 020911023A, 020911023N, 020911023F, 020911023FX and 020911023NX
  9. jmsheahan CGTI Graphics Designer
    Wiltshire
    Legend, thanks RJ.
    Found a 020911023F (looks like a Bora one) local. And that'll bolt straight up to an 020 box?
  10. rubjonny
    yep those numbers are all from the MK3 section, the MK4 also uses a version of the 020 box so thats why its listing it as Bora :)
    jmsheahan likes this.
  11. jmsheahan CGTI Graphics Designer
    Wiltshire
    Thanks John!
