Starting Problem - Lack of Power?
Discussion in 'Engines' started by dan_1987, Sep 1, 2007.
  1. dan_1987
    dan_1987 Forum Member
    Oh, my mistake. Either way, could painting the end affect the starter motor?
  2. dan_1987
    Taken from a FAQ on here. I'm confused now...
  3. paul_c Forum Member
    Yes, paint doesn't conduct electricity.
    Measure the voltages at various places along the way (take the 0V point as the battery terminal) while the car is being started, and you'll be able to work out where the current is being lost (ie because a voltage drop occurs).
  4. dan_1987
    Sorry Paul, my knowledge of electrics is pretty bad - Can you explain in more detail...
    Are we talking about the battery-to-starter lead?
  5. 82erGTI Forum Member
    Belgium
    If you have paint between the solenoid-to-starter strap or any other electrical connection for that matter, scrape it off first...
    You should really connect the - pole on the battery with the block using a jump lead, it's the easiest check ever... On almost all old cars i've tried this on, it made a big difference, starter turning over much better, an extra earth cable might just fix your problem for no cost, so be sure to check this first...
    If the problem isn't fixed yet and you want to play with ignition timing, scribe a curved line just along the 10mm bolthead, so you can always easily return it to what timing you run now... If you want to know how many degrees you're changing the timing, you can work it out by calculating the circumference (and this 'distance' equals 360)
  6. dan_1987
    Right, I've wired in a second earth from the battery to the gearbox. I'm sure it will help but it still started like a dog...
    I've also noticed that sometimes when the engine turns and fires (from stone cold), its slow (as in rpm) and then quickens up to idle. I'm not sure if that makes sense...?
  7. pigbladder Forum Addict
    cambridge , uk
    the paint needs to be cleaned off where the starter bolts go in
  8. dan_1987
    The paint is only on the body of the starter motor and solenoid as pictured...
    I'll try and remove it anyway. I might invest in a diesel starter motor - will a mk3 starter fit?
  9. pigbladder Forum Addict
    cambridge , uk
    oh paint on that bit is fine
    is that spade terminal earthed to the bolt head? or just looks like it?
  10. dan_1987
    I've just been out with the torch! I can't seem to see where the spade terminals go to...
    The only wire attached on the gearbox earth point is the main earth cable that runs to the chassis and then battery.
  11. dan_1987
    anyone?
    (on a good note, I've just replaced my gearbox oil with Redline MTL and its damn sexy)
  12. pigbladder Forum Addict
    cambridge , uk
    can you give a quick recap of what youve actualy done to try and fix it
    id still be thinking cables myself..
  13. dan_1987
    New battery
    New alternator
    Replacement starter motor (standard + painted as pictured)
    New battery-to-starter cable
    Cleaned earth points and starter motor wiring
    Doubled up earth cable (battery-to-g'box)
    Basically when the engine is stone cold, the engine will turn but can stop for a split second, and then it will continue.
    Alternatively (or as another problem) it will turn and fire but will rev below idle and build up to idle. As in, it chugs away on firing for 2-3 seconds, building rpm until it is idling cleanly.
  14. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    When was the engine oil last changed, and what oil did you put in?
  15. pigbladder Forum Addict
    cambridge , uk
    mine used to do a similar thing...i replaced all the battery /starter /alt cables and its cured
    have you put a mulimeter on the battery? just cus its new it might be dud or partialy flat?
    u still on msn ? i added you but havent seen you in a while
  16. dan_1987
    Yep, still on MSN - on it now in fact.
    Not recently tested the battery, but I recall it being fine when tested in the past. Even got a check at Halfords. I'm tempted to pick up a diesel starter motor anyway.
    Maybe I should replace the alternator-to-battery wiring?
  17. dan_1987
    I do it regularly - can't remember off the top of my head but it wasn't long ago.
    Fuchs 15w40
  18. pigbladder Forum Addict
    cambridge , uk
    the wires youve replaced , are they properly crimped /soldered or something you diy'd with pliers?
    best get a cheap multimeter on the battery while someone cranks it , and then on the starter terminal and see whats going on
    no point in using a diesel starter if its not getting the juice
  19. dan_1987
    All the wires are properly crimped etc.
    Car has been stood for just over a day and the battery is only reading 12.2V. Pigbladder reckons it needs a trickle charge so maybe I'll invest in a battery charger.
  20. paul_c Forum Member
    Things aren't adding up here, mate.
