steel to alloy glue
Discussion in 'Tools, Equipment & Fasteners' started by G60KG, Jul 3, 2012.
  1. G60KG
    G60KG Forum Member
    at work 'working'
    I have an inlet manifold with no hole or meat to mount a small throttle cable bracket to, similar to how it is on a mk3 agg engine. Will Araldite hold the bracket to the inlet or will it just fall off?
  2. Jagermeister
    Jagermeister Forum Member
    Being Trolled
    I recall that normal araldite can be disasembled using an oven...
    Does the stuff you show have something different in it to take the heat?
  3. G60KG
    G60KG Forum Member
    at work 'working'
    good question....I don't know will have to check
    EDIT: 70c max any other suggestions anyone?
  4. Jagermeister
    Being Trolled
  5. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Drill and tap some holes. Use locktite to seal threads.
  6. G60KG
    G60KG Forum Member
    at work 'working'
    this was my idea initially but a couple of people have suggested that ti would probably leak. Also there is not a lot of meat to tap a thread into. I'm tempted to try the durafix welding rods and maybe try sticking a lump of ali to the inlet and then tap into that. I did ask about the durafix stuff on here a while back and its supposed to be difficult to use but I think i might give it a go.
  7. vw_singh Events Team Paid Member
    Got any pics of proposed mounting area and parts please?
    I say drill an tap too.
    Gurds
  8. G60KG
    G60KG Forum Member
    at work 'working'
    bracket is very small 1 bolt similar to the one below
    I want to mount it to the inlet on the front to the right of the outlet shown in the pic. Don't think the metal is thick enough for thread is it?
  9. Track-Day-ABF Forum Member
    Get a stud tigged to the manifold.
    Rather than trying to mount the bracket to the manifold - do it t'other way round?
  10. G60KG
    G60KG Forum Member
    at work 'working'
    thats the other option I was thinking of. how common are aluminium bolts.
  11. whitemk2 Forum Member
    marlow
  12. G60KG
    G60KG Forum Member
    at work 'working'
    Quicksteel sounds like a winner. I will give that a go first before trying the others, thanks.
  13. rubjonny
    what inlet manifold is that, can you get me a part number? maybe the car its from has some kind of ingenious mounting bracket you can use? its not supposed to be screwed on the back is it, like an abf inlet manifold?
  14. G60KG
    G60KG Forum Member
    at work 'working'
    its a diesel inlet from a 1X so originally had no throttle bolted to it ;)
  15. rubjonny
  16. Mike_H Forum Addict
    Options:
    1. Try some sort of 'liquid metal' bodging option
    2. Make a bracket out of ally angle, and get it welded to the manifold - 4mm thick at least I'd think, to avoid stress cracking. Ally welding isn't that cheap though, even for a little bit
    3. Make a support bracket braced off the existing throttle body to manifold bolts, and either braced around the hose connection, or on the thicker boss piece on the back of the inlet
  17. i_am_me Forum Member
    riby
    could you take your isv monting bracket that bolts to the top of the rocker.
    weld that to the rocker cover so it cant spin round and use that to mount your throttle cable bracket onto
  18. TUBDUB Forum Member
    btown
    Sorry to change the subject but is that inlet on an 8v digi? Is there and advantages to it performance wise with the single throttle body?
  19. G60KG
    G60KG Forum Member
    at work 'working'
    Ive got some quicksteel just not got round to trying it out. Instructions sound cool though. You kneed the putty and it starts to warm up then you have 5 minutes to do what you want with it until it goes all hard on you.
    Inlet was only used as it was a bolt on option for the TB and PB head. Car is running on Megasquirt with that TB
