Steering rack removal - subframe drop?
Discussion in 'Mk3' started by PhilRyder, Aug 29, 2023.
  1. PhilRyder
    We need to remove and replace the steering rack. Is it possible to remove it without dropping the subframe? Will it slide out the side?
    Posted in mk3 but it’s a mk2 rack on a mk3 subframe in a mk2 car (not widetrack).
  2. Savagesam
    Yeah, drop the subframe, not enough space between the subframe and the chassis to get it out sadly
    PhilRyder likes this.
  3. PhilRyder
    Yes, I’ve seen a couple of threads that say you can slide it out but I don’t have a enough room between the car and the wall. Also the PAS rack is taller and won’t fit through the gap :(
