still getting strange noises from 1.8T
Discussion in '1.8 & 1.8T' started by Nicky Rider, Feb 11, 2007.
  1. Nicky Rider Forum Member
    Kernow/Hamburg
    hey guys hope someone can shed some light on this!?! when I start my golf from cold it makes this unhealthy noise... Some of you wrote back saying it 's probably the starter motor. So I had it checked by vw and they said yeah we'll stick a new one in(under warranty!). but the next morning I started it up and there it was again!? just wondering if anyone else has had this!? [:s]
  2. christatedavies New Member
    Yeah, I had the same trouble. VW said the same to me, replace the starter motor. But had a feeling it wasn't that, as it does start...
    Please do me a favour and keep me updated on any outcomes with this, and I will do the same for you.
    I posted earlier today here: my post, do you get the other issue I described?
    Thanks, Chris
  3. vrbanana Forum Junkie
    Sunny Sheffield
    Problems with the flywheel can cause a noise on start up
  4. Nicky Rider Forum Member
    Kernow/Hamburg
    Hi Chris
    no I don't get the problems you described... If i had a clue about cars I would try and sort it myself to but I'm a photographer! one of the fellas was saying it is a problem with the starter motors but surely it can't be with mine it's just had a spanking new one put in!? does my nut I only bought the car 6 weeks ago! lol[xx(]
  5. Matt82
    Matt82 Forum Addict
    GTI Scene
    what noise are we talking about? banging, spluttering, screeching, whizzing, crying...
  6. Nicky Rider Forum Member
    Kernow/Hamburg
    It's like a loud rattle when the engine starts !!! which only last a few seconds.. then does come back until the next morning...
  7. gary1210 New Member
    peterborough
    could be the flywheel you dont say what engine you've got some of the later aum code engines have a dual mass flywheel which are pretty poor
  8. Nicky Rider Forum Member
    Kernow/Hamburg
    Hey Gary it's a gti 1.8 turbo 03 plate.. it's got 32 thousand on the clock..
  9. gary1210 New Member
    peterborough
    if its an 03 its more than likely got a dual mass flywheel, i had a similar problem to be honest my local vw dealers weren't worth a w~~k i used a local specialist in the end,
    i think he removed the starter and inspected the flywheel that way i think it was to much movement in the seperate plates of the flywheel all this dual mass stuff is a bit of a mystery to me
  10. Nicky Rider Forum Member
    Kernow/Hamburg
    cheers geez! will try my luck with vw first, fingers crossed. have a good weekend!
  11. Nicky Rider Forum Member
    Kernow/Hamburg
    Yo
    supposedly it was the cam chain tensioner and the oil pump..... but i haven't had it back yet so can't say for sure.
    peace out
  12. oak8vgti Forum Member
    Chester
    never heard of that one on the 1.8t but yeah on the 1.2 + 1.4 engines
    but when i work at merc's we had a similar fault with the V6 making a noise on start up, merc's issued us with a special graphite grease to stick onto the ring gear, this instantly stopped any noises
    poss the same
  13. Turborat Forum Member
    Cambs
    If it sounds like a kind of 'growling' noise for about a second only on cold startup then I would say it could well be the starter motor.
    Ours has done it for the last couple of years and still starts fine but the noise is getting more frequent (not just the mornings).
    I know that the mk4 starters do suffer from this problem, I believe it is the solenoid slightly sticking on startup so I believe.
    We are not going to replace ours until it starts to have any slight issues starting which I've been told you will know when to definetly change it (not that it won't start at all;) ) as it will struggle to start before actually giving up.
    It could be another problem but it does sound like it could be the starter.
    Hope this helps.:)
  14. oak8vgti Forum Member
    Chester
    didnt read this post sorry :lol:
    teach me for quick reading
    yeah does sound like it could be the tensioner for the chain linking the 2 cams
  15. DarrenE Forum Member
    Hmmmm... Dual mass flywheel......
  16. oak8vgti Forum Member
    Chester
  17. Nicky Rider Forum Member
    Kernow/Hamburg
    Hey oak8vgti!!
    thanks again for the response! I'm just wondering if they are replacing the tensioner for the chain under warranty.. and I were to have the cam belt serviced at the same time would you still have to pay for labour on that??
  18. oak8vgti Forum Member
    Chester
    hi mate, if they are removing the cams to replace the chain (not sure if you have too) then just pay for the belt and tensioner as the belt will have to come off anyway, but you'd have to ask them but no reason why they shouldnt
  19. Tspec
    Tspec Forum Member
    Scotland
    anyone know what that noise is when you open the door on a mk4 golf?? loke a buzzing noise?hmm, always wondered.
  20. oak8vgti Forum Member
    Chester
    is it a tdi?
    if so its the tank sender priming the fuel system
