strange metallic chi chi chi chi rattle on acceleration
Discussion in '8-valve' started by Marky-gee, Oct 17, 2010.
  1. Marky-gee Forum Member
    northumberland
    its ecu controlled
  2. Robscottvw New Member
    Preston, Lancashire
    you time the ignition to 6deg btdc @2500 rpm using a timing light if its digifant. its easier to get a mate
    to sit in the car and keep the car at 2500rpm while you move the dizzy and hold the timing light.
    first get the car up to about 80deg C, swith it off, un plug the blue temp sender (or 4 pin type), start car again and time to the 6 deg. switch car off again, and reconnect the temp sender
    check this, check all vac pipes, clean all earths, check for exhaust leaks round the manifold,
    by your description it sounds like its probably pinking
  3. Marky-gee Forum Member
    northumberland
    I thought moving the dizzy on an agg did nothing?
  4. bens_cab Forum Junkie
    Ashford kent
    chi chi chi you sure its not cha cha cha and brucie isnt hiding in the bay lol
    i reckon theres a rattling heat shieod on the exhaust
  5. Marky-gee Forum Member
    northumberland
    Wrong, it's been tack welded and it ONLY happens UNDER load.
  6. sveltefog New Member
    Staffs
    Stupid idea but you seem pretty well stuck so.....is the alternator fan catching the alternator housing, the torque of the engine may move it a little if (IF) the alternator is not bolted down properly and/or the thorough bolt has worked loose, maybe the alternator fan bolt is slightly loose ?
    just guessing.....
  7. Robscottvw New Member
    Preston, Lancashire
    you tried timing it up yet?
  8. diggerbucket Forum Member
    Aberdeenshire
    Can't be that, the sound doesn't vary in frequency with the engine RPM.
  9. Marky-gee Forum Member
    northumberland
    what sensors would affect timing and where can i find them under the bunnet !!
  10. Robscottvw New Member
    Preston, Lancashire
    have you actually checked the timing yet tho dude?
  11. Marky-gee Forum Member
    northumberland
    No, I don't know how to, I also don't have a stobe.
    If any one would like to post up some pics or diagrams of were to start that would be helpful.
  12. Robscottvw New Member
    Preston, Lancashire
    borrow or buy a strobe and look in the haynes manual, there was even a how to on here!
  13. Peterhall New Member
    Penzance
    my golf dose this and had it over two years my brothers a mechanic and just said cause it get louder under load it was just excess fuel being burnt dunno if that right but never had a problem just an 8v quirk i think
  14. Brian.G
    Brian.G Forum Member
    West of Ireland
    Could be the half moon plate bolted to gearbox that shields flywheel. It can touch teeth sometimes. I know this because I caught mine the last day going over some branches. 5min later sound when away when it fell off. :lol:
  15. Marky-gee Forum Member
    northumberland
    quick update :
    I think im going to take a gamble on it being the exhaust manifold gasket, so this is the job im having done by VW(at discount) on tuesday.
    fingers crossed
  16. G40
    G40 Forum Member
    Portadown NI
    It's the exhaust manifold gasket wait and see.
  17. Marky-gee Forum Member
    northumberland
    Promise [:^(]?
  18. Marky-gee Forum Member
    northumberland
    UPDATE:
    I had the manifold gasket, downpipe to manifold gasket and inlet gaskets renewed today and the dam thing is still doing it.
    so back to square one as they say.
  19. Marky-gee Forum Member
    northumberland
    wrong [8(]
  20. Drew21 Forum Member
    London
    i was sure it would be the manifold gasket. rollocks
    From the descriptions above I was sure it would either be leaky exhaust manifold or pinking. Severe pinking comes with noticeable loss of power, don't suppose you've had any of this though or you'd have mentioned it. Do golf's ever crack their exhaust manifold?? I had a BMW with cast iron exhaust manifolds and both manifolds developed a crack (through heat stress I assume), sounded very much like pinking. You'd hope the VW mechanics might have noticed that though.
    what you need is a friendly rolling road so you can stick your head under the bonnet at 80mph
    keep us posted
    re timing, there is a guide on here which covers checking the timing on a digi. You will need a strobe though, or at least a borrow of one. You could try retarding it by hand (turning the dizzy with the direction of rotor rotation - clockwise IIRC) and see if that makes any difference. Not a fix but could be helpful for diagnostics. The ECU can only advance (or retard) a limited amount from the intial setting (dizzy position) so if you turn the dizzy enough the ECU won't be able to make up for it and the engine will run retarded
