sump guard s for motor sport
Discussion in 'Track Prep & Tech' started by smartboyo, Nov 28, 2015.
  1. smartboyo Forum Member
    hey any one here got sump guard on there car i have mark two golf which mostly use for track use, hiill climb s but am thinking having a go at some rally cross but am worryed about smacking my sump, as we all no the oil pick up sits very close to the bottom of the sump , what have you got on your car or done to help protect sump thanks for looking j
  2. Dave
    Sligo, Eire
    There's plenty out there. Do a web search, post pictures, and I am sure lots of people will have lots of different opinions.
    My SAAB Sport had a works sump shield, actually a skid plate cos. it was a 2 stroke so no sump.
    It was 6mm thick aluminium with rolled in corrugations, and a curved up front.
    I used it on my V4 SAAB rally cars and it was bullet proof.
    Bent a few steel wheels though!
  3. Jon Olds Forum Junkie
    I have a lot of experience of sumpguards, from years of autocross, rallycross and rallying.
    Two main things to consider;
    the guard and the mounting system (sorry of this is too obvious)
    The guard can be any lump of ali or checker plate you can lay your hand on (even seen a road sign being used)
    8mm is my preferred thickness.
    I tend to use 5mm thick 30*30 angle for the frame.
    Do not underestimate how strong it has to be. Use M10 bolts , not 8's
    The mk2 is reasonably straight forward, I always use the lower sway bar for the rear mount. Heavy gauge 1" square tube, cheap, easily replaceable.
    Always think about the sides and box in
    You must be able to throw a trolley jack anywhere under it and jack the car up, if it bends its not strong enough
    Hope this of some help
    Jon
    Nige likes this.
  4. Dave
    Sligo, Eire
  5. smartboyo Forum Member
    thanks for info jon and dave i did goggle search found very little omp sell a guard but doesnt look that good think making one is best route to go thanks j
  6. MUSHY 16V
    aberdeen
    i have dieselgeek sump guard on my mk4 it is pretty much like Jon has described
    both the guard and brackets are held on by vw M10 rivet nuts N 908 106 01
  7. smartboyo Forum Member
    mushy have you guard on because mark fours are known for creaking sumps when lowered or do you use this car for motor sport
  8. MUSHY 16V
    aberdeen
    I have this after cracking the sump on the original engine
  9. Jon Olds Forum Junkie
    Holed sump. Nightmare. Sump guard every time,
    Jon
  10. MUSHY 16V
    aberdeen
    Wasn't even a hole just two small cracks
    I agree about the sump guard the sump on the v6 is stupidly low
  11. TonyB Paid Member Paid Member
    Ammanford, Wales
    Here's a pic of my MK2 night event car's sump guard.
    The rear bolts are drilled through the sub rear sub frame, the front has a 1" steel box welded to the front subframe with captive bolts welded in. Probably 5mm plate, had a hard life, seems to work. The guys I purchased the car off said don't worry about rocks and boulders just head for them, the sump guard will sort them our., so I guess its ok.
  12. smartboyo Forum Member
    brill tony be love it have done a lot looking omp sell one but not sure if its up to it , not been able to fine any one else who makes them
  13. Jon Olds Forum Junkie
    The ones you buy may well not be great value and I would seriously have a go at making it yourself.
    I used a new mk2 escort kit cut down years ago for my mk1 and was not really happy with the result
    Jon
  14. TonyB Paid Member Paid Member
    Ammanford, Wales
    As Jon says^
    I buy a lot of Escort bits off rally design and adapt them, this sound like its tried and tested - sounds like a good start. Of course depends on what kit you have available but with a welder and disc cutter you can do most things :) . The basics are all there just need chopping about a bit. Normally far cheaper to buy a similar looking kit of parts than buying all the components yours self.
    Their 4 link kits can be used for all sorts, it's essentially a Golf MK1 Tubular wishbone set in kit form ;)
    vw_singh likes this.
  15. Jon Olds Forum Junkie
    As Tony says, with the escort stuff they have a larger market, so can up the volumes.
    Jon
  16. smartboyo Forum Member
    update finlay found a man to make up sump guard for my car wont be able to make for a while but when he does ill post pics he works on rally cars and have seen his work so am happy to use him turns out he s a 2 miles up the rd from my folks lol small world thanks for all input
