Now that there's no search thingy for the old forum.. I'm wanting a decent setup for my Mk2 Golf.. 40mm drop about.. Can be up to 60 Comfortable ride.. not bothered about Racing or anything.. I also want someone to fit them and set up camber and trackinga at the same time.. Any suggestions for products and companys to get them from ? TT Edited by: TommyT
not hard to fit urself with standard tools then take it to any good garage to set camber and tracking on a mk2 take wheel off remove bolts from suspension leg one 17mm and one 19mm and the top bolt not sure of that size remove brake pipe from clip take off suspension and refit as u di to take off on the rear remove wheel take out 17mm bolt from axle and the top bolt from inside the car then press down rear axle and slide suspension out refit as done before couple of hours work
i thought the koni top adjustables and eibach springs were one of the best rated setups, think they are about 400+ for parts only though.
i think the only point in goin for (low cost) coilovers over these is if you wanna slam it. unless you can afford to spend up near 4 figures on coilovers that have rebound and bump adjustment on them.
eibach springs and any good quality shockers will be good. i have bilstein on mine and can't fault them
