Swapping an 02j for 02s in a mk2?
Discussion in 'Transmission' started by Tristan, May 22, 2018.
  1. Tristan
    From a general look around here, reading the likes of Eddies Jenvee thread etc, am I right in thinking that once you've "02j'd" a mk2, swapping to an 02s is simple? I'm using a cable clutch, and a Polo shift tower.
    Is the 02s gear change sweeter than 02j? Will my Polo shifter and cables swap over?
  2. Toyotec
    The gear change is the same quality.
    Any Golf or Polo/Ibiza shifter works.
    I also use a clutch cable.
  3. Tristan
    Thanks Ed .
  4. dogzila Forum Member
    You can't use 02S casing in mk2....You should use 02J casing with 5 speed forks, 02J selector...
  5. Tristan
    Why can't you?
  6. dogzila Forum Member
    Because you can't bolt it to gearbox mounts. Casing is different. Missing holes for mk2/mk3 gearbox bracket.
    I have done 02J 6 speed in mk3 :) I know.
  7. Toyotec
    ^^ He is right.
    I did not just bolt an 02S to JENVEE. If it was a bolt up, then there is nothing to report.
    The gearbox was taken to Martin in Wales and the while the guts is 100% 02S, the casing is 02J as is the bellhousing.
    That allows the fitment to be a strightforward '02J/02A conversion.
    Best speak to Martin who knows these gearboxes to a tee!
  8. Tristan
    Apologies if I seemed argumentative. It was an honest question, I didn't know the answer, I wasn't doubting you.
    Thanks for the explanation.
  9. dogzila Forum Member
  10. Hotgolf
    Smelly Cornelly
    Adjusting the fork isn't an issue. With the case built up and in neutral, just adjust as necessary so the finger is loose on the fork . Then try the tower by hand with the case off.
    They also missed out a vital step in that write up.
