Hi All, I've been experiencing a starting promblem with my mum vw polo 6n 1.4 Auto. Some times when I turn the key the starter won't turn, then other times the starter turns but the car don't start. Once it switch off while driving and sounded to be misfiring. I've check the fuel and spark. Both are working. Although the plugs looked abit blacky. I've changed the lambda sensor after getting these codes. 00525 00537 00532 Does anyone know what the prob can be?
If you Google that numbers one by one Look for Ross tec wiki It should be the first link you see Is on my phone anyway Things it could be for one the battery sounds duff or you have a bad earth Check for air leaks The lambda probe could be duff or it's wiring Could be a few other things as well you'll see them in the links
